I'm a newbie so I may use the wrong terms but here I go. I have used this program (tmpgenc) about 20 time to convert avi (maybe divx avi,i don't know the real difference) files to mpg to make vcds. All the sudden when i browse and pick avi source it doesn't put the audio source with it on the main TMPGE screen. I use Stream Type -System [Video + Audio] but it changes itself to Stream Type - Video only. Now I have no audio source. I have never had this problem and I tried converting a avi file that I converted in the past successfully and I have the same problem. I have never use an audio dub program. I just converted video+audio. Last night it worked fine. I converted a file to mpeg2 and burned it and played it. Now I can't convert anything and get the audio to show up. Can anyone help me? Please
try checking options,enviromental settings, VFAPI plugin and making direct show multimedia file reader a priority of 1
this worked for me
chris -
if it a divx file you'll have to rip the audio fromth movie with virtaldub..... then just add it to TMPGEnc for audio source......if you have syn problems rerip the audio in virtualdub but put on full processing mode on
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 14:03 -
need to replace audio source with a different source
By sec1968 in forum AudioReplies: 0Last Post: 6th Mar 2011, 22:59 -
Understanding TMPGEnc source material settings
By brassplyer in forum Video ConversionReplies: 1Last Post: 5th Mar 2011, 06:41 -
TMPGEnc, Vobsub and mpg files as source
By kubak in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2009, 16:52 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 17:11
