hi i hope that someone can help, i have been using virtualdub to check for bad frames on a piece of avi video, it tells me that there are bad frames, how do i know what ones they are?,how do i view the bad frames?, how do i delete them?? and what difference will it make to the finished film, ie will there be a chunk missing in the film???
please help if you can
thanks pete![]()
From the VDub Help section:
Deleting JUNK chunks from a file
VirtualDub never puts JUNK chunks in any AVI file it creates, so the solution is to turn off all processing:
· Set the video processing mode to Direct Stream Copy.
· Set the audio processing mode to Direct Stream Copy.
· Open the source file, and save to the output file.
Audio interleaving options work in this mode, and video range selection works to the nearest key frame, so you can re-interleave or trim off ends at the same time.
Hello.
Problems re-using VirtualDub
By djdust in forum Newbie / General discussionsReplies: 17Last Post: 27th Apr 2011, 08:57 -
.mkv problems in Virtualdub
By alc112 in forum Video ConversionReplies: 14Last Post: 10th Feb 2010, 23:47 -
virtualdub dv type 2 problems
By sander815 in forum Video ConversionReplies: 26Last Post: 21st Nov 2009, 19:58 -
Problems with Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 09:23 -
A couple of VirtualDub problems.
By Rein Engel in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2007, 03:07
