Here's my problem...![]()
Movies won't rip faster than 1.8 - 1.9x
Here's my specs...![]()
Sony 16X DVD
2.4Ghz Intel P4
512 DDR PC2100 Ram
SmartRipper w/ adaptec ASPI from tools section
28gb ATA 100 western digital 7200rpm
DMA/Ultra DMA on
Tried everything in Bios....
Am I missing anything?
Results 1 to 9 of 9
Its safe to ASSume that he's using XP, Note his CPU w/ P4 !!
else, w2k -
Their "computer details" indicate W2K.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
whats up man? if you're running XP than trying going to RUN: Msconfig
go to the STARTUP tab and uncheck all the unnecessary things that don't need to load. If you don't know what not to load then go to google and do a search. Then, after thats done, go to RUN: Services.msc
Unload all services that don't need to run, including IMAPI CD Burning. Once again, if you're unsure what services don't need to be run at startup try searching a google. This all will also make your computer run much faster. Apologies if you've already done all this already, it is unclear what you have and haven't done. Oh yea, make sure your jumpers are set correctly on the back of your HDD, DVD-ROM, etc. Re-install ForceASPI from doom9.org. Theres a nice little program called enditall I believe. It'll shut down anything running, or something like that. you can always try that. Oh yea, and try using another ripper, later -
one other thing, while you should do your tweak your startup and services menu, you should first try updating the firmware for your DVD-Rom. that usually takes care of it
Thanks guys.
I fixed my problem. I use Windows2000.
My bios was set for DMA, but I had to set it to DMA in my device manager.
Thanks Everyone!!
How To Speed Up and Slow Down the Footage
By blewyn in forum EditingReplies: 6Last Post: 25th Jan 2012, 21:46 -
HL-DT-ST DVDRAM GSA-T20N read speed too slow!!
By tmangia in forum DVD & Blu-ray WritersReplies: 10Last Post: 17th Aug 2010, 05:44 -
Question about ripping when internet speed is too slow
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2009, 02:49 -
Slow Read Rate
By mr240 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2008, 17:41 -
How to slow down speed of Mpegs?
By lillei55 in forum Newbie / General discussionsReplies: 5Last Post: 10th Sep 2007, 17:40
