  1. I run ASPICHK and I get the following info:
    WNASPI32.DLL 4.711(0)
    WINASPI.DLL 4.60(1021)
    ASPI32.SYS 4.711(0)
    WOWPOST.EXE 4.60 (1021)
    and the message at the bottom says: ASPI is not properly installed. One or more components have been replaced with older version of the software.
    What should I have for XP? Apparently 4.711 is the newest, but how about the 4.60 versions or do I even need those 2?
    Jack
  2. some claims that ver 4.7 potentialy give you a problem, I would suggest ver 4.6. But i'm not sure becuz I'm, myself still using forceASPI haven't had a chance to upgrade yet. Other ppl might have different idea keep listen to them.
  3. Jackee, What you have seems to be correct to me, I have the same versions.
