i have a m2v and a AC3 file that i need to mux together to create vob files. somebody said that i could do it with spruce up but i can't figure out how to do it. can anyone help me.
thanx
As long as the files have the same filename, Spruceup will import the audio when it imports the video. Spruceup will not import the audio separately, but only with the video with the same filename.
dO THEY HAVE TO HAVE THE SAME FILE EXTENSION ASWELL AND ARE YOU SUPPOSED TO BE ABLE TO HEAR THE SOUND WHEN YOU SIMULATE WITH SPRUCE
You should have a "movie.m2v" and "movie.ac3" file. Use "Add media asset" to import the "movie.m2v" and you should see it import the "movie.ac3" immediately following. If the .ac3 is a different name, then name it correctly, delete the movie asset, and then re-add the movie asset. SpruceUp should find the .ac3 and import it.
You should be able to hear the sound in SpruceUp if your system can playback AC-3 encoded soundtracks. I'm not sure if there are other requirements (such as having a software DVD player that can decode AC-3). -
This is a test response. This is not related to this thread, except only as a test.
Spruce Encoders
By zerohash in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 06:10 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 02:59
