I'm trying to export an QuickTime Movie of 580 MB into a Toast VCD Format. I get the error that the video is too long to fit on a CD. What's wrong?
How long is the movie? If it is over about 79 min then it won't convert it.
With Toast you don't. Toast will only convert standard VCDs, not XVCDs. Thus only up to 79min is allowed.
ok, so except the small amout of movies shorter than 79 minutes you can't use toast to bring your dvd movie into a vcd disk?
Which program can I use instead? -
Well I always cut my movies into segments that would fit on 2 vcds. You can then use Toast to convert and burn them.
rosazeh,
Buy QT Pro and you can split movies into as many pieces as you want. Then you can burn each piece onto a 74 min VCD with toast.
-S
QuickTime Pro exporting image sequence with the frames in the wrong order?
By adam-tl in forum Video ConversionReplies: 2Last Post: 29th Nov 2011, 15:55 -
Final Cut Pro, gives me GENERAL ERROR when exporting to Quicktime
By Huntr777 in forum MacReplies: 8Last Post: 30th Sep 2011, 14:26 -
quicktime pro will exporting to h.264 solve this huge file size issue?
By cybershot in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2010, 21:43 -
Quicktime Problem: Playing and Exporting
By hzgg2 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2008, 15:48 -
Problem exporting AVI to H.264 in Quicktime Pro
By newsclips in forum Video ConversionReplies: 2Last Post: 31st May 2007, 00:46
