hi all.. please help me,
I'm using SmartRipper 2.40, it was just fine yesterday, and today I installed some softwares, now each time I start SmartRipper, it says "no DVD found". So I can't rip any DVDs
Also, now each time I start Nero, it says "Could not open driver. Trying system aspi". But then after that the Nero can operate normally.
What could be wrong? How can I fix it? Thanks very much
Sounds like you need an ASPI.
Maybe you lost it somehow...
Get it in the tools section of this site, and install in the same folder as smartripper. -
Sound's like you need to reinstall Windows, you know that it is recomended that you reinstall your OS every 6-12 months.
DVD to VCD made eazy
http://www.eazyvcd.tk -
jimot,
It might help if you included in your post exactly what software you recently installed prior to experiencing this problem. Another burning program perhaps? If so this could have damaged your ASPI layer or overwritten it. Also there is newer version of SmartRipper available (2.41 I believe as of this date) that has few bug fixes in it. Nero also posted an update a couple of days ago, v.5.9.9.9, so might want to consider upgrading them and see if it fixes your problem. -
I installed DVDx and then uninstall it, then I install TMPGenc.
I've tried the Adaptec ASPI driver and the other one ASPI driver from the tool section, but still smartripper says "No DVD Found".
Then I use nero's ASPI and followed the instructions, then my Nero goes back to normal but smartripper stays the same.
I'm using win98SE.
Thanks -
I know this is a very stupid question but do you put a DVD in the drive when you open Smartripper? Try using a different ripper. Try DVD Decrypter.
Yes, I did put the DVD disc in my DVD-Rom
I already tried DVD Decrypter and it works!
But I'm still wondering what happened with smartripper, it was just fine the other day...
Anyway, what's the difference between the 2 ripper? Which is better?
Thanks -
What ripper you use is a personal choice,each one has it's advocates. I prefer Smartripper,I find it more versitle than others. DVD Decrypter is O.K.,but I have never gotter it to work in stream mode without locking up my computer. Have you tried re-intalling Smartripper 2.41 ?
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57
