I baught a new dvd combo (lg) . the manual says that it supports vcd 2 and vdc 1.1 , I TRIED to watch several movies , but all of them I saw in slow motion and the sound was coruppted . I TRIED several burns with diffrent methoods but without succees. I USE easy cd creator and tmpeg software . I AM SURE that the problem is in the way I BURN the films to vcd .
the link that show the dvd is :http://www.sakal.co.il/OneProduct.asp?PIC=1020&ProdID=4898
the model is DC-595NW. I ALSO TRUSSFERED the dvd to be a multizone .
please help me if you can
Does your player say it plays CD-Rs or CD-RWs? That is the question. VCDs in your owner's manual refers to the commercial type VCDs.
Hello. -
Where did you get all those movies? Make sure if they are standard VCD not XVCD. Check player list of compatibility to see what your player can do. If you can, try to play commercial vcd and see if the problems still there.
Jerky playback
By hi2shy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Nov 2010, 16:44 -
Jerky Playback
By electrowiz in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 16:16 -
jerky playback
By VOYAGER2009 in forum Video ConversionReplies: 19Last Post: 22nd Feb 2010, 05:27 -
Jerky playback on TV from PC using TV Out
By digidude in forum Software PlayingReplies: 0Last Post: 30th Dec 2008, 17:26 -
Jerky playback of AVI on TV
By kostnkost in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2008, 16:32
