When i convert a Avi-file to Mpg with Virtualdub+subtitler and TMPGEnc at 98% i get the following message: "Write error occurred at address 004028A9 of module TPMGEnc.exe with 00900EB0" and converting stops. Doing it over converting stopped at the same point. What can i do about it?
Before you tried to convert to TMPGEnc, did you select Video-->Scan video stream for errors in VDub?
Hello. -
I did it after the error-message and the scan gave no messages. Looking at the Avi you see no bad video.
Load the AVI in VDub again. Save as AVI. Try to convert this new AVI file.
Hello. -
OK. doing so, VDub advises to compress first in full processing mode. Clicking on "compression" a lot of possibilities appear, so ?what to choice
When encoding a avi to mpeg, all I do is encode it with tmepg. I only use virtualdub to see what the frame rate is. Just open tmpeg, and encode your avi without using virtual dub, then use easy video creator to create the vcd data file and to burn it. I have made a bunch of vcds this way and they have all worked fine on my dvd player. I am burning on a regular memorex cdr and my dvd player is a sanyo dvm 370.
Yes, but i need a dutch subtitling, so i need to use Virtualdub with subtitler filter!
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 12:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46
