hi all
I captured a movie to DivX. I followed almost all instructions from the "How to capture to DivX in realtime"-page, but unfortunately I forgot to click the "Lock video stream to audio"-button in the settings-menu of virtualdub. During capturing about 40 frames were dropped (length of movie is about 1 1/2 h ) and now video and audio donīt match because of my mistake. Are there any possibilities to get audio and video of the DivX avi-file synced with free software like virtualdub?
Thanks in advance
Yes.
1. Load the AVI file into your Virtual Dub.
2. Select Video-->Scan video stream for errors, and remove any junk frames.
3. Select Audio-->Full Processing Mode
4. Select Audio-->Conversion-->44100 Hz
5. Select File-->Save as Wav....
6. Launch TMPGEnc, close the wizard
7. Load the original video as input video, and the new wav file as output video.
8. Select Load and your favorite template
9. Select Start and the resultant file should be what you had in mindHello. -
Hi again
Unfortunately your advice didnīt help. I scaned the movie, but virtualdub couldnīt find any junk frames. Are there any other ways to get audio and video synced? -
Yes, I usually refer the person to audio resynch guide(s). But before you do that, can you tell what you VDub preferences are as supposed to Selecting Options-->Full Processing, and selecting Options-->Preferences. Just tell what values are there.
Hello.
"Video: Stream attributes could not be determined" in Sony Vegas
By bloodshed in forum Newbie / General discussionsReplies: 41Last Post: 6th Nov 2012, 06:12 -
Joining HD MOV files from camera & saving as mp4; "Invalid Audio Stream"
By maskingtape in forum Newbie / General discussionsReplies: 30Last Post: 23rd Aug 2011, 12:30 -
Eac3to "Clipping Detected...2nd Pass" --> Avi2DVD finds no audio stream
By Murk in forum AudioReplies: 4Last Post: 5th Aug 2010, 16:27 -
"LOCK" in Panasonic DMR-EH55
By jcrojasc in forum DVD & Blu-ray RecordersReplies: 2Last Post: 15th Dec 2008, 01:22 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 18:49
