yo
i'D like to know if theres any chance to take a screenshot of an svcd clip, or maybe exporting frames in .bmp
thanks in advance![]()
Lots of ways. What's you favorite encoder? VDub does it by Video-->Copy Source fram ti clipboard
TMPGEnc does it by File-->Output to File-->Sequence...Hello. -
i can't open .m2v videos in VirtualD, and as for tmpg... i dont want a sequence or so
is there something like premiere where i can go to a certain scene of the clip, adn then export the frame as .bmp???
i dont want to export all frames of the video, i'd like to take maybe one or two
screenshot aint working, and premiere doesnt work with .m2v videos neither -
Make an avs script to open the video, then open the .avs in vdub and poof.
or you could use DVD2AVI and frameserve it to vdub -
hey we're in the newbie conversion forum, please handle me like that and dont bombard me with all these kick ass high tec words
if you want only one or a few snap shot, PowerDVD can do that, but if you want more, let say a short few seconds clip, then you have to get into kick ass hi-tech word.
I would suggest you to use DVD2avi to get d2v file out of your m2v, load d2v file in TMPGenc, set source range (a part you want). set size you want in setting video tab. now you can export to any image format (bmp, jpd) you want by in File tab goto "add current project to batch list" and choose sequence BMP/PPM/TGA....... and then hit start. As simple as that, did i use kick ass hi tech? :P
PS in Plus version you can load m2v directly to TMPGenc but I'm not sure about quality, thou.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 08:53 -
Cutting Mp4 between I-frames, replacing some frames
By eymerich in forum EditingReplies: 4Last Post: 29th Jul 2009, 08:41 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
