Results 1 to 9 of 9
  1. Hi all,
    This is my first post, and thanks for a very usfull resource!
    I have managed to convert a divx to mpeg, with some really good qualuty results, Thanks agin for the templates :P
    However I wish to chop a 1.3Gb vcd into two smaller files, but have tried several programs that are recomended, but they lock up and fail.
    I use XP, with 2GB processor and 1Gb 333DDR ram, what tool would you recomend.
    Many thanks
    shagi
    Apr 2002
    The State of Frustration
    Try Ulead video Studio. Load the dat file into it and split the video.
    Hello.
  3. I had the same problem.
    Use DVTool, it's available on the tools page on VCDHelp.
    The split command works great. You can really fine tune the sizes.
    hope it works
    clmlh
  4. Thanks guys, I tried Ulead virtual studio, and I will try this one as well and post which one i prefer.
    Shagy the Shagmaster
  5. You could also try VCDcutter. Its an easy to use prog with good results.
  6. Hi all
    And thanks your your input, well I have usedd all three products. And I will tel u later the one I prefered - lol
    VCDCutter - locks up (may be user lack of intervention)
    DVDTool: I am really thick and could not get any results
    VirtualStudio: professional loocking and very easy!
    Thank you for help :P
  7. Member spidey's Avatar
    Apr 2001
    U.S.A.
    You did try the cut command in TMPG right ? If not that shouldn't have a problem if it was the encoder you had no problem using to encode with.
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  8. TMPGenc and VCDcutter never give me any probs. Are you sure you are doing it right? And what exactly do you mean by they lock up?
  9. VCDCutter just bomes out! , (does not load)
    But also be aware I only been doing this, for a short time.
