I've twice downloaded a movie which on both occassions turned out to be corrupt. I've removed the bad frames by using virtual dub. It now says that there are now no frames however when played back in windows media player the movie cannot be fast forwarded and when it does, then video remain static or turns black but the audio moves forward. It fails to open at all when using DivX Player. Reindexing (whether with Virtualdub or DivFix) causes sync problems with the video and audio and does not resolve the problem when opened in media player or divx player. I tried to recompress the file and that resolved the problem however the quality of the video is now terrible. Is there any way i can recompress the file without a deterioration in quality or decompress the original video and audio and the recompress whilst still preserving the quality of the avi file.
I need to keep a copy of the avi file on CD before converting to mpeg to play back on a DVD player. Any help will be gratefully received. Thanks
Results 1 to 10 of 10
Fast forward is a common problem with AVI's that don’t have many keyframes, but this does not mean they are no good. Having removed the junk frames, go straight to TMPGEnc and start the conversion. Stop after a few minuets to check the output.
Keyframes ever 300 etc are fine for playing from start to finish, and wont effect the conversion, keyframes every 10 are fine for editing and skipping through the video -
Thanks KingJohn. There were np problem converting the file to an mpeg format and the file worked fine, fast forward included. However I still want to keep a copy of the original avi form as backup. I've sometimes encountered problems when copying corrupt avi files from a CD to my hard drive (CRC errors) and therefore not been able to copy them. I don't particularly want to come across this problem and the mpeg file is too big for a single CD. I therefore need to make sure that the file is okay before copying it to a CD.
Again, I've also downloaded a avi file with audio sync problems which i want to correct before copying the avi file to a CD. I assume that this means following all the documents on audio synching. Does this not also mean that I have to recompress the file after I've corrected the synch problems. Which takes me back to the original problem. Is there anyway to recompress to a new avi file without losing the quality of the original? -
if you get it suynched in Vdub you could frameserve directly to TMPG.
http://www.vcdhelp.com/virtualdubframeserve.htm~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
:-? Apparently, I am a bit more of a newbie than I thought. Basically all I've done to date is experiment with converting from avi to mpeg to vcd. What exactly does frameserving do?
:wink: Right, thanks, anyway I've decided to just experiment with the file and see if I can correct the audio sync problems and at the same time learn something more about encoding, compressing, conversion etc. What I would like to do is make the aspect ratio for the file slightly bigger. (It's currently 640x272). I'm trying to make it at least 640x288 before saving it as a new avi file. Could you recommend a programme that can do this. Virtualdub does not appear to have this facility and Tmpgenc appears to be for mpeg files only.
You may apply a RESIZE filter under VIDEO in VirtualDub, then Frameserve that into TMPG
~~~Spidey~~~
:( A resize filter? I've had a look in v1.4 of virtual dub and although I can see the Filters, I can see a resize option. Sorry to be a pain, but i'd appreciate it if you would 'splain to to me like a 10 year old or point me to where i can get further instrauctions. Thanks
Making the size bigger can result in the quality going out the window, However it can be done to the AVI or done when converted to mpeg 1. Usually using TMPGEnc to change things during conversion is preferred.
Vdub
Video > full processing mode
Video > Compression > codec > bitrate (needed for full processing mode)
Video > filter > Add > Resize
TMPGEnc
Load > VCD/SVCD Template
Load > Unlock Template
Setting > Video > size
Changing the size of the mpeg 1/2 to anything other than the correct size, may render the disk useless on your DVD
mux xvid without recompressing anything?
By redrocklobster in forum ffmpegX general discussionReplies: 5Last Post: 12th Jun 2010, 10:35 -
AVI/Xvid->MP4/Xvid w/o recompressing?
By chconnor in forum Video ConversionReplies: 15Last Post: 9th Feb 2010, 16:47 -
Recompressing Audio Stream
By jdvideo in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2008, 18:04 -
Recompressing Audio
By usermm in forum Newbie / General discussionsReplies: 17Last Post: 8th Jan 2008, 10:12 -
problem encoding error decompressing video frame 0 :
By goingape in forum Newbie / General discussionsReplies: 7Last Post: 27th May 2007, 13:14
