am using the newbie guide method of try to rip to a single VCD...ie CLADDVD -> .d2v project and .wav from the DVD, then TMEGenc to encode/mux...the problem is that if I use the Wizard to set the bitrate, the output file is muck larger than predicted...for exmple...95minute movie with 850kbps CBR video and 224kbps audio should yeild an 804MB file , instead it yeilds a 997MB file (and the bitrate seems to vary from 800 to 1Kbps)...any ideas
Results 1 to 1 of 1
Invalid audio bitrate error on TMPGEnc Authoring Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 12th Jun 2010, 23:13 -
VirtualDob error message about variable bitrate *solved*
By Meriks in forum EditingReplies: 9Last Post: 14th Feb 2010, 08:39 -
Error in Variable bitrate (VBR) audio detected
By Russo in forum AudioReplies: 9Last Post: 12th Feb 2010, 08:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 11:16
