  1. Is this possible? I'm trying to save this file - http://disturbed1.com/prayer.300k.mov - it's a streaming Quicktime movie, I was hoping AsfRecorder could do this, but it could only snag the asx version (which I expected), but the .mov version is much higher quality for both video and audio. Does anyone know of a program that can do this? It would be very much apprectiated.
  2. You Need Streambox VCR, you can download it here:
    http://www.afterdawn.com/software/video_software/video_tools/streambox_vcr.cfm
    Ignore the little warning, if they didn't wat you to download, it why would they upload it to their servers.
    Click download and after it downloads unzip the exe file and install the program. Reply to this when you've done all this.
  3. Oh yeah if you want to download streaming QT real player files you need to extract all the files from fr_svcr1b31_crack.zip into the same folder as the vcr.exe then run fr_svcr1b31_crack.exe and you're all set to go.
  4. 1.After you do all that stuff you open vcr.exe and click the little planet with a plus sign on it.
    2. Paste this link next to where it says location: rtsp://demand1.stream.aol.com/wmg/us/wbr/disturbed/disturbed_prayer_300.mov
    3. Go down to where it says filename and change disturbed_prayer_300.rm to disturbed_prayer_300.mov
    Pretty easy huh.
  5. One more thing, if you try to preview it it will give you an error in Quicktime, wait till its done to watch it, double-click preview only works with Windows Media and Quicktime MP4 files.
  6. It worked, but the file won't play. Thanks anyway.
