Hi folks,
Is there anyone who can tell me how I can encode a movie with a bitrate higher than 192 bit. I´m using VIDEO CD PAL stream.
TMPGenc does not support this bitrate and I really want to encode this movie.
Thanx,
If you select the video cd pal template in TMPGENc it should be 224 kbit/s for the audio.
TMPGEnc Authoring Works - bitrate too high
By ecc in forum Authoring (DVD)Replies: 9Last Post: 19th Feb 2009, 13:06 -
TMPGEnc Xpress bitrate calculations are off
By Taeran in forum Video ConversionReplies: 3Last Post: 24th Sep 2008, 17:17 -
DVD Shrink and TMPGENC bitrate problem
By haddockd414 in forum DVD RippingReplies: 2Last Post: 12th Mar 2008, 12:31 -
TMPGenc won't allow bitrate to go below 1600??
By bebopdeluxe in forum Video ConversionReplies: 3Last Post: 10th Aug 2007, 18:49 -
ISO advice on what bitrate I should use in TMPGEnc....
By RKelly in forum Video ConversionReplies: 4Last Post: 26th Jul 2007, 12:13
