Hi, I used SmartRipper to rip 2 dvd's. But when I use PowerDVD to play them, using the new IFO file on the HDD it says "No compatible disc in D drive, please insert".
Also, if I try to convert it (using DVDX) halfway through it says "drive maybe locked, try playing with a dvd player like powerdvd" and stopped.
If I use powerdvd to play just the vob files they play fine, so im guessing the ifo must be pointing the software at the wrong location for the vob's, but as I'm fairly new to this I have no idea how to correct the problem.
Any help or advice u could give would be appreciated.
anyone got an idea? please? i have tried moving the files into a directory called VIDEO_TS, as someone else posted that idea here, but it made no difference.
Thanks -
I don't think Smartripper makes "compatible" Ifo files. I assume your trying to play the DVD from the HD. Download IFOedit. Use it to create a new set of ifo's after you delete the ones Smartripper made. The ifo's that Ifoedit makes are compatible,I use all the time.
I would suggest you not use one of those all-in-one programs. Use DVD2AVI and Tmpeg,you'll be much happier with the results.
Problem with newly ripped subtitles
By Spread in forum SubtitleReplies: 0Last Post: 25th Apr 2010, 15:37 -
Problem backing up my copy of transformers 2,i got it ripped but can't burn
By sscottsa in forum DVD RippingReplies: 1Last Post: 22nd Oct 2009, 18:18 -
Ripped dvd conversion to xvid/divx weird audio problem
By victoriabears in forum Video ConversionReplies: 1Last Post: 12th Feb 2009, 13:41 -
problem getting ripped dvd to play in my standalone
By rmb3 in forum DVD RippingReplies: 7Last Post: 25th Jul 2008, 04:16 -
video problem that is ripped from DVD with fairuse
By yunakokimama in forum DVD RippingReplies: 1Last Post: 20th Nov 2007, 21:33
