  1. Gidday all,
    Do anyone out there know how to convert a Karaoke DVD to VCD. I have tried the normal way but I can't seem to turn off the voice thats singing when I played it on my DVD Player.
    <font size=-1>[ This Message was edited by: ducman on 2001-08-13 16:15:05 ]</font>
    Aug 2001
    Netherlands
    i have this problem too, can't anybody help us??
  3. When running DVD2AVI, make sure you select a different audio track (music only). This way you will end up with VCD that has music without vocal.
    I like to make VCD with vocal on/off but don't know how yet.
  4. Cheers!!! I'll give it ago and let you know if it works.
    Thanks again.
  5. Hi everybody im new here and i saw your post and wanted to help
    Awhile ago I had the same problem but now I figured out how to make a l/r audio channel in one vcd so you can switch between vocals/music during karaoke playback.
    To do this first you must use DVD2AVI and get the audio tracks with vocal/music and the other track with the music only.
    Then use a wav. editor to turn the two audio tracks into mono
    After that is all done use Cool Edit or something similar to join the two mono tracks into one stereo track by putting one track in the left channel and the other track in the right channel and then save your new stero wav file and use Tmpgenc to convert ur dvd and on the player just you can now change the left/right channels
    I hope this help, let me know if everything goes well
  6. lol, lol, lol
    Nice one )
