Hi
i have some Divx's that instead of mp3 audio have Windows Media Audio V2, when i play them i cant hear any sound, i ahve WMP 8 since i have XP. So how can i get the audio to work?
someone once mentioned installing the Nimo codec would solve it but can anyone tell me if this can conflict with the Div X 5.0.2 codec, will they run concurrently?
thanks
Baz
Go to Microsoft site - they have all the WM codecs for download
http://www.microsoft.com/windows/windowsmedia/download/default.asp
or direct:
http://download.microsoft.com/download/winmediatech40/Install/8.0/WIN98Me/EN-US/wmpcdcs8.exePanasonic DMR-ES45VS, keep those discs a burnin' -
Hi thanks, but i already have those, i think the problem has something to do with Divx, not letting it use the WMA codec. from what i can gether Nimo tells it to use the WMA codec hence fixing the problem but i need to know wether this will cause any problems with my existing Divx Pro 5.0.2 codec?
cheers
baz
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 16:12 -
Windows 7 Media Center to use Windows Media Player for MKV
By pvong in forum Newbie / General discussionsReplies: 4Last Post: 31st Jan 2010, 10:26 -
Windows Media Audio 9 & Vista
By jasonphillipstx in forum Software PlayingReplies: 5Last Post: 6th Sep 2008, 21:49 -
Windows Media Encoder broadcasts audio from one PC but not the other
By geek2330 in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2008, 12:48 -
How to trim your video and audio within Windows Media Player™
By DmitryV in forum User guidesReplies: 0Last Post: 20th Jun 2007, 04:53
