Is it better to always include an AUDIO_TS folder in a DVD disc even though it's always empty? Does it really make it more compatible?
And does it make a difference if the directory names are lowercase or is it just better to make them all uppercase. Are all the files supposed to have uppercase filenames too?
u better not go off center..........ALL MUST BE UPPERCASE....
you dont want coasters do you? better use the audio folder
also,i forget it sometimes and dvd-r still play in sony,you
can fool around if u want..have fun -
Originally Posted by dvdmiester
you can of course add a LOT of other folders and things to a dvd and name them pretty well anything you want .. even just stuff in the root is allright .. -
Thanks, I'll just keep an AUDIO_TS folder in the root directory and I'll keep everything uppercase.
As far as the files inside the VIDEO_TS directory: do they need to be all uppercase also (my authoring program creates them all uppercase except for two files called Anchor and Volume, should I change those to uppercase?) -
Anchor and Volume you can remove completly -- they dont need to be there ..
everything else uppercase
AUDIO_TS folder
By siluet in forum Newbie / General discussionsReplies: 14Last Post: 10th Oct 2009, 07:00 -
AUDIO_TS file is empty
By LaNoche in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2009, 19:35 -
HELP!!. . .DVD Without AUDIO_TS Folder???!!!!
By sniperloc in forum Authoring (DVD)Replies: 13Last Post: 17th Feb 2009, 12:29 -
Another folder than Video_ts and Audio_ts
By claudiofran in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2008, 13:39 -
No Audio_TS files?? HELP!!
By onlyoneman in forum Authoring (DVD)Replies: 5Last Post: 8th Jan 2008, 11:19
