Hello,
I have been trying to make a "music video" by capturing video clips from my VCR, and putting them together with a song in Windows MovieMaker. Everything went very well, using the ATI card to capture, and compress etc, and then edit in Movie Maker. I even saved the movie as .avi instead of the default .WMV because Nero won't accept WMV.
But when I tried to burn it, Nero said that there was an error- "no fixation"
What does this mean? Please help me! I have searched the forums for an answer, and I would love to save my video on a CD, but I am all out of ideas. Can anyone help a confused newbie please?
Results 1 to 14 of 14
Microsoft does not allow decoding of WMV. Basically, you have two choices
There r some guides for converting WMV, they may work
You can start over.
WMV is a properitary format and they don't want u decoding it, because it's suposed to be Secure Digital media. -
Panasonic DMR-ES45VS, keep those discs a burnin'
Thanks for the help folks.
I know that WMV is "uneditable" as per Microsofts wish, but Windows Movie Maker is the only editing software that I have. I tried the link on this site for MovieXone and one other free editor, but without success. Any ideas for other free editing software?
Thanks again from a Spielberg wannabe. -
Use "Vdub ASF"
http://www.digital-digest.com/dvd/downloads/virtualdub.html
Or the old Vdub 1.3C, TMPGEnc will also open WMV/ASF files
Make sure you have the hacked codec, install the Nimo codec pack
http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/ -
Thanks for the replies everyone.
I decided to just give up on Windows Movie Maker altogether and not even bother with WMV files... they are waaaay too much hassle. Thanks again. Cheers -
Indigo Girl:
You can save yourself many hours of frustration by just buying "real" video editing software. Personally, I'm quite fond of Ulead's VideoStudio 6.0. I read these forums in total amazement at the absolute backflips some people do to accomplish the simplist of tasks. Also, you can just about read any forum page and the same two software products come up time and time again with the same problems over and over again.
If you would like to capture, edit, encode and burn without ever leaving the program try VideoStudio @ www.ulead.comEvil flourishes when good men do nothing. -
You are right about that. But I guess doing digital backflips is the price we have to pay using 5 or 6 different freeware programs, instead of buying one commercial "all-in-one" program. I have researched the Video Studio package you mentioned, and I was quite impressed by it. However , being financially limited right now, I will have to continue the virtual gymnastics for my video-editing hobby.
Cheers. -
Originally Posted by Spicuzza
Great so you like Video Studio, but many don't !, many prefer to use "Simple" tools to do a simple job, most of the time there are NO problems converting, editing, or making VCD's DVD's with just one program "TMPGEnc" its only when things go wrong that people want "Simple" programs to cure the problem.
Recommending Video Studio to fix a simple problem is absurd -
Originally Posted by Indigo Girl
Also half the fun of this hobby is fixing problems, how boring would it be if you downloaded a movie and put it straight on a disk to play on a DVD player... No fun it that at all.
Stick with what everyone uses until you know exactly what you want. Most of those "Other" programs are available as trial-wear, "Try before you buy" but don’t fill up your computer with them all, try them one at a time.
I think in the end for simplicity of use, you wont beat the fun we have with Virtual Dub and TMPGEnc -
KingJohn,
You're correct.
Recommending professionally written software that works is absurd.
I'm sure all of these recent posters are just having a blast with their hobby spending hours fixing simple problems.
VirtualDub Error - improper VBR audio?
Audio out of sync using ATI and TMpgenc
WinXP problem with VDub...?
Please help, asap - No sound w/Virtual Dub
TMPGEnc "cannot open, or unsupported" my MPEG2 fil
Virtualdub
Vdub won't open my avi (maybe divx) file
TMPGEnc. is pissing me off
TMEGenc bitrate predicition error
tmpgenc MPEG1 CBR bitrate problem
tmpgenc vxd vmm(01) error message
TMPGEnc slider locked in Merge & Cut
Need help with Vdub codec error
Problem cutting movie with TMPGEnc
virtualdub problems
TMPGenc MPEG2 Cutting\Editing Problem
Can't see MPEG2 files in TMPGEnc
"half the fun of this hobby is fixing problems"Evil flourishes when good men do nothing. -
Well, different strokes for different folks, as they say. As long as everybody can find a method or program that they are happy with, that's all that matters in this VCD world.
And as for my original problem, it is all fixed- finally! I ended up doing exactly that devinemi83!Thank you to everyone.
Cheers
Looks like Indigo Girl used TMPGEnc in the end and had no problems..
Removing nasty, sticky, slimy DRM from news station videos - how can you?
By GymGirl in forum Newbie / General discussionsReplies: 6Last Post: 23rd Mar 2012, 22:59 -
HowTo deal w/ nasty "audio streams have diff sample sizes" errors in WAVs!!
By KneeRow in forum User guidesReplies: 0Last Post: 25th Jul 2011, 12:43 -
Nasty Premiere Pro / Soundbooth AC3 bug
By Asterra in forum AudioReplies: 3Last Post: 11th Jul 2011, 03:06 -
How to remove nasty animated logo?
By Bonie81 in forum EditingReplies: 4Last Post: 7th Jul 2011, 10:34 -
Nasty Windows XP problem
By MeDiCo_BrUjO in forum ComputerReplies: 10Last Post: 6th Aug 2007, 09:35
