  1. Hello I have a problem. I have used dvd2svcd and it works good, however the last few minutes of every svcd I have made are bad quality. For example I have a movie split into two svcd and the last few minutes from the first svcd are always disturb. They falter.
    What can I do????
  2. if you're keeping it on your hard disk and it looks bad (not likely) you need to re-encode with a different mpeg2 encoder, it your record it onto cd-r you probably need to not overburn your cd-r some of my vcds wont play because i used overburn
  3. My player is also a bit sensitive. I have seen the same manners and solved them with another burningspeed.
    Cheers // Radioman
