It said 700Mb-80mins on the CD-R, does that really mean i can burn a 80min VCD movie on a this 700Mb cd-r?
For VCD and SVCD --- Yes!
80 minute disk = 800 MB mpeg
74 minute disk = 740 mb mpeg
Those numbers are give or take depending on the media add another 20MB if you overburn the disk. The reason is that DATA disks use more error correction than music, vcd, or svcd's where there is an acceptable ammount of corruption that can take place from scratches or other degridation.
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 11:15 -
Embarassingly simple capture question
By eclipse95 in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2007, 13:12 -
Simple Question: True or False?
By jcm0320 in forum Capturing and VCRReplies: 10Last Post: 23rd Aug 2007, 22:33
