I have suddenley been unable to encode to, or play SVCD. I have been using TMPGenc and had selected the 1st 35 mins of a film to encode, and successfully encoded it and burned it to disc. I was shocked to find that when I went to encode the 2nd and 3rd parts of the film the resulting file was a normal vcd resolution, the wrong aspect ratio and with a very jerky framerate. Windows Media Player came up Error downloading codec whenever I played them whereas before the codec was already there and no downloading was needed. It certainly appears that a file has been corrupted or lost. I downloaded from the divx website the "svcd mpeg codec" which is for tmpgenc to encode svcd and was instructed to use the prog to remove the old components and reinstall them, which I did. Although this cleared the error message on Media Player it still plays at the same shocking frame rate and resolution, it burns to disk with the same quality and Nero will not encode as it says it is missing the necessary encoder which has to be bought by mail order(!) In short, I cannot convert anything to SVCD anymore. Can anyone help?
Yes my mate suggested that as the first thing to try and it didn't make any difference
Problem with conversion to DV
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 09:54 -
conversion problem
By thomeski in forum Authoring (DVD)Replies: 2Last Post: 25th Apr 2010, 21:45 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Help conversion problem!
By milney100 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 06:51 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11
