Hi
when i rip region 1 dvds to vobs then through dvd2avi and then encode through tmpegenc the sound is always out of sync . any ideas please
When you get your avi file do the following:
1. Load the AVI file into your Virtual Dub.
2. Select Video-->Scan video stream for errors, and remove any junk frames.
3. Select Audio-->Full Processing Mode
4. Select Audio-->Conversion-->44100 Hz
5. Select File-->Save as Wav....
6. Launch TMPGEnc, close the wizard
7. Load the original video as input video, and the new wav file as output video.
8. Select Load and your favorite template
9. Select Start and the resultant file should be what you had in mind.Hello. -
Thanks for your reply but this is not an avi file but a dvd rip d2v file and seperate wav ripped from the vobs with dvd2avi
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
help sound syncing probs usig Nero7
By polbol in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:19 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 21:35
