How do I screen caprture a frame from a DVD movie under Win XP ?
I tried turning down the media player vid acceleration settings but it didnt help.
Ive already got the movie "SmrtRipped" to my hard drive but wanted to grab a few frames at hiquality before converting to VCD.
Many thanks
You could use DVD2AVI to get an AVI file. Load this file into Virtual Dub, find a scene that you like, Select Video-->Copy Source Frame to Clipboard, and you scene will be in the clipboard.
Hello. -
Just loaded up PDVD.Originally Posted by bugster
Problem there is the little camera icon is greyed out! argh no!!! LOL
Would this be because its a decrypted VOB on my hard drive or because its the standard edition that came free with with my LiteOn DVDROM drive ?
Many thanks for your help. -
It's because you have a "crippled" version of Power DVD. On the full version you can capture frames from ANY video source opened in the player.
Hi folks,
I downloaded their latest upgrade patch and it now works perfectly
Help plz. :Capture AVI issue : Bad chunk in frame data: Invalid length
By chindoo in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2011, 20:51 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
How do you print a frame to look as good as it does on screen?
By johnharlin in forum Newbie / General discussionsReplies: 3Last Post: 23rd Oct 2010, 08:14 -
DVD screen capture resolutions???
By cabala420 in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2008, 12:28 -
Capture JPEG Screen Caps From DVD
By philly33flyers in forum DVD RippingReplies: 10Last Post: 25th Aug 2007, 12:48
