Please can anyone help as i am at a loss, i have downloaded an avi file from the net and have been trying to convert it to mpg so i can put onto a vcd, everytime i convert it i get the sound but no picture, also when i use tmpg and try to use the section where you can adjust the start and end frame is still dont see any pictures, yet the file plays perfectly on windows media player, please please help as i am tearing my hair out!!
thanks pete
Results 1 to 10 of 10
Okay, leave the golden tresses alone and do the following:
1. Load the AVI file into your Virtual Dub.
2. Select Video-->Scan video stream for errors, and remove any junk frames.
3. Select Audio-->Full Processing Mode
4. Select Audio-->Conversion-->44100 Hz
5. Select File-->Save as Wav....
6. Launch TMPGEnc, close the wizard
7. Load the original video as input video, and the new wav file as output video.
8. Select Load and your favorite template
9. Select Start and the resultant file should be what you had in mind.Hello. -
thanks i will give it a try, the other strange thing that i forgot to mention was the fact that i can convert using nero's in-built encoder but you dont get any options about changing to widescreen etc, and suing nero seems to take a lot longer.
cheers pete -
In TMPG, try increasing the directshow priority to 4 under Environmental Settings, in the options. Turn everything else to 0.
Originally Posted by Tommyknocker
i did all of that and i'm still not getting any picture, just audio. -
Could you encode it again, please? This time, when you launch TMPGEnc, turn the wizard off. Load your video and audio, select Load. A list of templates will appear. Choose the one that applies here. Select Start. Give us the results when you are done.
Hello. -
well sometimes its the easy option that works best, i changed the direct show priority to 4 and everything works a treat, thanks everyone for all your help, again!!!!
cheers pete 8) -
can you look at my other thread and see if you have any suggestions for that too?
VOB2MPG converts to MPG with no picture
By darrell1979 in forum Video ConversionReplies: 6Last Post: 14th Oct 2009, 14:29 -
Converting .WMV to .MPG and losing audio/picture
By frenchdb in forum Video ConversionReplies: 1Last Post: 29th Jun 2008, 20:42 -
Best settings voor TMPG Express MTS Files to Divx Avi
By jeremyotten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Mar 2008, 09:36 -
TMPG DVD Author 3 won't open FVFW avi
By jasoncolz in forum Authoring (DVD)Replies: 0Last Post: 7th Dec 2007, 15:21 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41
