I had downloaded the Vanessa Carlton - Ordinary Day music video in ASF video format with Kazaa.
I wanted it as a VCD compliant Mpg so I could play it on my DVD player. I found the audio was not good enough quality to convert so wanted to use the Mp3 track of the same song as the audio.
I tried using TMPGEnc but the audio was about 2 seconds ahead of the video.
I found on this forum a mention of a program called Goldwave which could help me.
http://www.goldwave.com/
I used the program to add 2 seconds of silence to the beginning of the Mp3 track which I then used with TMPGEnc to convert with the video and it worked!!
I had timed with my stopwatch that it was about 2 seconds difference and it seems I was right!
I still wish there was a program that could play a video and separate audio file at the same time so you could get a more accurate time difference.
Is there such a program?
I used TMPGEnc 2.5 with an ASF file? I thought it only worked with an old version?
Results 1 to 1 of 1
HD PVR - Audio not synced with video
By lacywest in forum Video ConversionReplies: 5Last Post: 29th May 2010, 09:20 -
Video/audio not synced problem. (Avisynth)
By michcio in forum AudioReplies: 0Last Post: 18th Jan 2010, 12:43 -
Tight synced audio + subtitles, poor synced video...
By goodbot in forum SubtitleReplies: 5Last Post: 13th Jul 2009, 22:59 -
video and audio are not synced up
By maniac in forum ffmpegX general discussionReplies: 2Last Post: 27th Apr 2009, 21:53 -
audio and video wrong synced.
By michcio in forum Authoring (DVD)Replies: 0Last Post: 18th Feb 2009, 18:08
