OK, I actually got this program to work. I got the proper serial entered and when I entered it, it said SUCCESS. The problem I am having, it will tell you how many blank discs you will need to copy the movie using a DVD ROM drive and a standard burner. It makes the first disc with no problem (and looks perfect on a standalone DVD player). My problem is, it never asks me to insert another blank disc to continue the burn process. Their tech support is useless and I was wondering if anyone has encountered this and gotten past it.... if possible... Thanks!
I'm using dup-dvd too, and first I make the mpg file to my hard disk, not straight burn it with dup-dvd.
Then I'll use Nero to burn the vcd.
DUP 5990/37 - Pal & NTSC all the time?
By mraroid in forum DVD & Blu-ray PlayersReplies: 18Last Post: 12th Dec 2008, 12:56 -
Toshiba RDXS32 - High speed Dup freeze
By medare in forum DVD & Blu-ray RecordersReplies: 0Last Post: 14th Jun 2008, 13:33
