    What is the best method of creating a dvd from a 720 x 480 avi file using cce????? Do I have to do all that frameserving like I had to do to create an SVCD??? What should the bitrate be???
    WOW no one here has any idea of how to do this. Am I just so clueless that no one want to respond. Can someone at least point me in the right direction????????. Can I at least get a hint from a moderator???????
    Sorry for the bump.
  3. Are you using cce as a standalone or or with premiere? If standalone, drag the avi to cce. Double click the file and enter the relevant info. Do not exceed 9000 for the bitrate and check the dvd compliant box. Read the help forums for all the other info you will need. This will get you going.
  4. Isn't there a 2GB on avi size? If so, how to do AVI with larger size?
    Jul 2002
    BATON ROUGE, LA - U.S.A.
    Where I walk, I walk alone. Where I fight, I fight alone.
