Hey all,
Just as the above, how to do it? I have tried with nero, but only have the VOB and no IFO or BUP files?
Any help is appreciated
De-mux the vob and re-mux as an MPG to whatever spec you are burning e.g. VCD, SVCD or DVD. If the latter then you will need to author the MPG which will turn it back into a vob but with the necessary IFOs.
Ifoedit has an option to create ifo's. It will create ifo's for any vob,just rename the vob as VTS_01_1.VOB,this necessary for Ifoedit to work.
Single .VOB file into working DVD?
By AHK in forum Authoring (DVD)Replies: 14Last Post: 5th Sep 2011, 11:38 -
Need Advice on My Single Vob
By striker9 in forum Authoring (DVD)Replies: 7Last Post: 11th Aug 2010, 06:36 -
dvd burning with a single vob file
By rtr720 in forum Authoring (DVD)Replies: 1Last Post: 17th Jan 2010, 03:22 -
DVDFab Platinum - rip into single Vob?
By nrishiraj in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2008, 17:33 -
Single vob file in MacTheRipper?
By bmoney017 in forum MacReplies: 2Last Post: 20th Oct 2007, 02:07
