How do i get TMPGENC to encode divx movies with mp3 audio compression to mpg
Results 1 to 10 of 10
How is it not working?
If it is encoding the film but not the sound then try ripping the sound to a wav file first using virtualdub.
Then select the seperate sound source before encoding.
If this isn't the problem then tell us exactly what is (or isn't) happening. -
an error occured when audio was decoded is the error message i get before the encoding even starts
Panasonic DMR-ES45VS, keep those discs a burnin'
