sorry my english!
i have pionner a03 in my dell computer,i make my dvd with dazzle dvd complete (only it work fine), but i will move to brazil and don't know the region # there and how to change my system to burn dvd to play in Brazil? thank so much for advice!
Your ao3 will change it's self if you play dvd from that region
I think. If not there is softwear that can do it. -
To change region go to :
- Control Panel
- Administrative Tools
- Computer Management
- Device Manager
- CD Rom
- Right Click on your DVD R
- Select Properties
- The Menu Proposes you a DVD Region section with a list of code per country. Brazil is 4.
Be careful though, you can only change your region code 4 times.
Good Luck -
By default, DVD complete doesn't include region protection. Unless you specifically set it to a region, the DVD that you make will be region free. You will have to encode it to PAL mpeg-2 as Brazil uses PAL (and not NTSC).
Incidentally, I believe that you can buy a converter to play both NTSC and PAL-M videos if you need one.
http://www.codefreedvdplayers.com/CONV_TNLB_tr-7_DTL.shtml
Otherwise you can make your DVD-ROM player on your computer region free by changing its firmware to a region free one (there is some risk to your drive in doing this) and installing the Region Killer freeware program. This would allow you to play DVDs from any region on your computer.
http://perso.club-internet.fr/farzeno/firmware/
Another alternative is to buy an Apex DVD player. Some of their DVD-Video players can play DVDs from any region with a mod chip or modified firmware. I am guessing that the Apex plays PAL-M as it will play just about anything you give it. The Apex uses technology similar to a DVD-ROM player.
http://www.nerd-out.com/darrenk/index.htm
http://www.apexmodchip.com/index.html -
Here is a similar question which may help you.
http://www.dvdplusrw.org/cgi/ikonboard/topic.cgi?forum=2&topic=2990
Look for DVD player that can change from region 1 to all regions
By plk1758 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Feb 2010, 10:27 -
Code to allow DVD use on all regions
By eaglet in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2009, 11:04 -
Unlock LG DN798 for all regions
By Jduque in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2007, 11:13 -
How to change regions on a DVD or TV?
By SnowStormWolf in forum ProgrammingReplies: 1Last Post: 8th Jul 2007, 17:11 -
All Regions Hack
By Mickey11 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th May 2007, 02:26
