I used VCDGear to convert a VCD DAT. format into a mpeg format.But it is too large for my hardisk.What format can I convert it into and how to make it smaller???
Th'nkZ
http://www.vcdhelp.com/vcd.htm#comp
Go here and do the math vs. the quality you want.Hello. -
Originally Posted by cnsane
Once loaded select
Video > full processing mode
Video > compression > DivX 3.11 Alpha (Low motion) > bitrate 400?
Audio > Full processing mode
Audio > compression > codec (DivX or MP3) 40Kb > 16 bit stereo (try others, depending or source)
SAVE AVI
You now have a DivX AVI movie at the fraction of the size, and if the input quality is good, then the output will also be good.
If you just want another copy of the VCD, do a disk to disk copyor load .dat into any VCD authoring program
Problem with sharing a video to different formats with Premiere Elements
By coriscow in forum EditingReplies: 1Last Post: 17th Dec 2009, 23:36 -
problem with mpg format
By volam in forum EditingReplies: 0Last Post: 17th May 2009, 13:31 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
mpg to DVD problem
By toughdiamond in forum Newbie / General discussionsReplies: 14Last Post: 21st Nov 2007, 06:17 -
Problem with .VOB to .MPG
By SilverFalcon in forum Video ConversionReplies: 2Last Post: 30th Jul 2007, 13:27
