In some faq i read that in mentioned case composite cable will be better choice over not only rf, but s-video. Is that true?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Well, kinda not that i asked - as signal was already RF - air translation. So it's composite already. Can somebody clarify this ?
If you have an S-Video connection use that. It will always give you better results than composite unless of course you have a card that supports component video, but I've yet to see one on the consumer level.
As an aside...
S-video is the best ASSUMING the device that sends the signal has the better color comb filter. If you had a poor composite to s-video device ( probably what's in the VCR ) it will make it impossible to recover the lost color information that could be recoverd by a 3d comb filter. A DVD has superior color information so s-video would be appropriate.
If you are just going into a cheap capture card then don't worry too much composite is all the VCR and RF were capable of anyways. I high doubt that the capture card has a 3d comb filter.
VCR: Remove the Tuner
By themaster1 in forum RestorationReplies: 7Last Post: 1st Feb 2011, 04:29 -
USB TV Tuner to watch cable
By gothamcity in forum DVB / IPTVReplies: 4Last Post: 21st Jan 2011, 20:22 -
Analog Cable TV to HD LCD Monitor via TV tuner
By torrentkid in forum DVB / IPTVReplies: 0Last Post: 3rd Aug 2010, 07:19 -
recording cable HD channels on pc tuner/capture card
By Zipbiscuit in forum DVB / IPTVReplies: 2Last Post: 26th Dec 2009, 10:52 -
Recommendations for a USB Cable Tuner
By Boegy3 in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2008, 14:21
