I download dvdx to encode my mpegs and i was wondering what video and audio bit rate i should use.
If I were you, I would read some more of VCD/SVCD info which can find just right here on the left side. Then I would decided which format I want and complatible with my dvd player. I would stick with standard setting as much as possible with very first movie I encoded(which can find all setting in here also). Then the more I get comfortable with encoding I would check out some XVCD/XSVCD becuz they are better quality but less complatible.
In favor of convertinn from divx to mpeg I would read more of convert guide which located here also.
Bit Rate Vs Quality
By kashif71 in forum Video ConversionReplies: 20Last Post: 21st May 2010, 01:19 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Bit Rate
By shapper in forum Newbie / General discussionsReplies: 10Last Post: 2nd Jun 2008, 15:04 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
the right bit rate
By nojee in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 04:00
