This is really annoying and it makes my resulting MPEG2 streams look bad and jerky.
I am encoding a 29.97fps DV-compressed AVI to 29.97fps MPEG2 with my own SVCD template in TMPGEnc 12i.
This is what happens (pretend that each number represents one frame) This is one second:
1, 2, 3, 4, 5, 6, 7, 8, 8, 8, 11, 12, 13, 14, 15, 16, 17, 18, 18, 18, 21, 22, 23, 24, 25, 26, 27, 28, 28, 28.
As you can see, TMPGEnc encodes the same frame one third into the second 3 times, and it does this about 3 times during each second. Then it skips to the correct frame, resulting in video that slightly "jumps" 3 times every second. This only happens during high-action scenes. When the action calms down and there aren't as many moving things on screen, then it fixes itself to 1, 2, 3... 30.
Can I fix this? Or should I just use a different encoder?
_________________
AP Enterprises Ltd.
<font size=-1>[ This Message was edited by: AP Enterprises Ltd on 2001-08-13 13:33:19 ]</font>
Results 1 to 1 of 1
Annoying video/audio sync problem
By WebMaximus in forum DVD RippingReplies: 2Last Post: 12th Nov 2011, 07:59 -
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 13:43 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 10:31 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Annoying blackscreen problem with AVS video editor
By in flames in forum Newbie / General discussionsReplies: 0Last Post: 4th Dec 2007, 23:10
