I always use Nero to burn the VCD's and SVCD's, but always burn Disc at Once with no chapters.. If the VCD I have was ripped from a DVD, sometimes they add chapters, so there are additional 'index' points, and 'flags' added in the .cue.
This type won't burn with Nero without causing an error (I think it will burn using Track at Once, but I hear that's not the right way to do a VCD), so I have to edit the .cue to burn w/o the chapters.
Can anyone tell me how I can burn the SVCD with this type of .cue file?
The only 2 programs I have that have worked for me are Nero and Sonic MyDVD, but the Sonic doesnt let you load a image file.. Other burners like CDRWin don't seem to be compatible with my Pio DVR-103.
Thanks!
I use VCDEasy to burn the Bin files with CDRAO, if your burner is not supported then you can try to force the driver, my Lite-On burner works with the generic-mmc-raw driver
Worth a try as it puts all the chapters in for you
Panther
All say Grrrrrrrrrr...................... -
When it detected my burner it didn't have a compatible driver for it, but there is a box with a drop down menu titled Force Driver, and there are some generic drivers.
Panther
By first installing ForceASPI1.7, and then forcing driver 'generic-mmc', it will write the cue without the chapters. but this .cue it still gives me the error 'Cannot send .cue to drive':
FILE "movie.bin" BINARY
TRACK 01 MODE2/2352
FLAGS DCP
INDEX 01 00:00:00
TRACK 02 MODE2/2352
FLAGS DCP
INDEX 00 00:05:12
INDEX 01 00:07:12
INDEX 02 00:07:13
INDEX 03 08:45:54
INDEX 04 16:23:73
INDEX 05 23:58:41
INDEX 06 31:41:58
INDEX 07 39:12:62
INDEX 08 46:50:15
INDEX 09 54:17:23
INDEX 10 62:08:62
INDEX 11 70:00:21
INDEX 12 78:27:32
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
