I lost my bin/cue burning capability when I switched from Nero 5.5.9.0 to RecordNow Max 4.1. What do you use to burn bin/cue to complement Recordnow Max? I heard there are problems installing both Nero and Recordnow Max in the same machine.
I need the bin/cue burning capability for use in DVD2SVCD.
LastQuark
TRV900/DV500/CCE/Impression DVD
Premiere/Avisynth/Ricoh 5125A/
DVD2SVCD/RecordNow Max -
If I were you I'd download and install the latest version of Daemon Tools. With this you can mount the cue on a virtual drive and burn it as a direct disc copy. You can find it at: http://www.daemon-tools.com. It's also usefull to check whether or not DVD2SVCD created the bin/cue file properly before you waste a CD since it does screw it up from time to time.
lastquark,
You are correct about Nero not getting along with other burn software.
I tried using NTI and Nero together and I lost some functions in NTI.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
