Hi,
Do you know if this player (SAMSUNG DVD V1000) supports PAL VCD's?
I know that it plays VCD's and SVCD's but I'm not sure if the PAL format for VCD's is supported.
Basically, I want to purchase some VCD's from several stores on the web. Mostly (if not them all) are in PAL format.
Check this site (they say that the VCDs are in PAL format) : www.allvcd.com
Thanks for your time.
Thanks, for taking the time to reply.
The reason why I'm posting is that I already called Samsung and no one was able to give me a clear answer (they don't even know what a VCD is), so I believe that a Samsung DVD V1000 user who has purchased VCD's on the web will be able to provide me with a clear answer. -
Maybe your talking to someone who cant understand english.
But good luck in your search.
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 11:45 -
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 10:34 -
Samsung BD-P1590 VS Samsung BD-P1500?
By Darkerknight123 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 3rd Jan 2010, 17:51 -
Samsung HT-Z210, Samsung HT-X250
By emmy207 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Mar 2009, 23:06 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42
