Just ripped The One and its almost ready to burn. However, there is RCE checking in the VIDEO_TS.IFO. I've removed RCE on a few titles before, but I don't fully understand what to change it to on this title. The code is this:
Set GPreg<9> mov SPreg<player region code>
Set GPreg<9> and (set-val) 255
If GPreg<9> == (cmp-val)<4> then (LinkPGCN) Link PGC 3
Set GPreg<13> mov (set-val)<1>
Break
I think this was a region 1 and 3 disc, so don't understand where the 4 comes from. And extactly what does Break do? The film plays fine using IfoEdit and with WinDVD4+, except on WinDVD when I click on some of the menus it just comes up Stop.
Should I just NOP the check or change it to LinkPGCN Link PGC 3?
Also, IfoEdit 0.932 appears to be serioiusly broke and I've deleted 0.91, so can anyone tell me where to get 0.91 from?
the easiet way to remove rce was to rip it to the drive then open the ifo up in the region patch bit in dvdecrytor & pat the ifo & bup files... found this easier than ifoedit as it didnt even remove it to me like.
kev!
problem with MPC/HC after spyware removal
By spiritgumm in forum Software PlayingReplies: 4Last Post: 6th Mar 2011, 10:55 -
Watermark removal
By Shrimpy72 in forum ffmpegX general discussionReplies: 3Last Post: 14th Jan 2011, 12:31 -
RCE Protection Issue
By tryst1 in forum Authoring (DVD)Replies: 1Last Post: 24th Jan 2010, 10:53 -
WMP CP removal
By kookie2000 in forum AudioReplies: 2Last Post: 14th Jan 2008, 17:41 -
RCE protection removal..............
By efiste2 in forum DVD RippingReplies: 12Last Post: 21st Jul 2007, 13:42
