i have ripped a dvd with smartripper and want to use the ac3 sound file when i encode it to a smaller dvd using tmpgenc. does anybody know if this can be done. once i have resized the dvd i will use ulead dvd workshop to author and burn.
cheers
chris
Yep. Just use TMPGEnc's MPEG tools to multiplex the files back together into an .mpg.
You can then import the .mpg into DVD Workshop and author your DVD. Make sure you check "Do not encode compliant files" before burning the DVD. That way DVDWS won't try to re-encode your finished .mpg. -
cheers mate will give that a go, i take it i need to multiplex it to an mpeg2 file
chris
On the fly software AC3 encoding
By djdynamite123 in forum AudioReplies: 12Last Post: 24th Jul 2011, 16:35 -
Arbitrary AC3 Re-Encoding by DVDStyler
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 6th Sep 2008, 15:57 -
Problems encoding from Vegas to Divx and AC3
By grendizer in forum Video ConversionReplies: 0Last Post: 6th May 2008, 04:30 -
No Audio when encoding with AC3
By Stankia in forum AudioReplies: 2Last Post: 25th Apr 2008, 18:44 -
AC3 dialnorm encoding
By RobinReumers in forum ffmpegX general discussionReplies: 0Last Post: 6th Jun 2007, 09:35
