As everyone knows vcd's can be made with nero. Well just recently i have come across a probem. I've burned thousands of CD's and hundreds of VCD's yet this is the first this has happened and for the moment i am bewildered. I have recently downloaded some mpegs that once nero analyzed the files and added the track it says the file is 837MB when its only 455MB. Any ideas?
(º·.¸(¨*· .¸ . ¸.·**· .¸ . ¸.·*¨)¸.·
«´¨`·.¸. *Prince of Piracy* .¸.·´¨`»
(¸.·º(¸.·¨* *¨·.¸¸.·¨* *¨·.¸)º·.¸) -
So nobody has any ideas? Viewed 30+ times and nobody has had this to happen and anything to say about it?
you say that you d/l mpeg from internet, which might not be standard one. Then you use Nero which try to encode to standard format. That might be you answer.
You can try to check if that file is in standard format or uncheck "create standard compliant CD" in Nero and see what you get. -
It has no problem adding the file to a track so it has nothing to do with standard compliance. It would burn if didn't say it was bigger then burn medium.
No, never had this to happen - mostly as I left Nero as a lost cause long ago. For all my VCD burning needs, I use VCDEasy, which gives U much more info and options than Nero.
/Mats
Nero problem
By Doopopmercury in forum Newbie / General discussionsReplies: 8Last Post: 11th Apr 2012, 06:14 -
Problem with nero. I think!
By breeze9 in forum Video ConversionReplies: 3Last Post: 9th Jun 2008, 11:40 -
Nero vision VCD autoplay
By Aliyans in forum Authoring (VCD/SVCD)Replies: 8Last Post: 31st Dec 2007, 10:54 -
Nero Problem
By alley04 in forum Authoring (VCD/SVCD)Replies: 3Last Post: 6th Sep 2007, 18:08 -
consolidate vcd files with Nero Vision, but problem with playback
By slh888 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2007, 17:36
