What do i need to use to remove frozen frames from avi files, so i can encode them with mpeg2
Avi defreezer doesnt work.
yes, I know which frames are bad
what do i need to do ?
thanks - like the quote ! -
You are welcome about the quote.
Anyway, once you have the video loaded in VDub, you can delete them out one by one, or VDub's answer is the following:
Take your pickDeleting JUNK chunks from a file
VirtualDub never puts JUNK chunks in any AVI file it creates, so the solution is to turn off all processing:
· Set the video processing mode to Direct Stream Copy.
· Set the audio processing mode to Direct Stream Copy.
· Open the source file, and save to the output file.
Audio interleaving options work in this mode, and video range selection works to the nearest key frame, so you can re-interleave or trim off ends at the same time.
Hello. -
Still not having a
any luck removing my bad frame from a file,
tried the direct processing using virtual dub,
but still copies exact - not sure how to delete them.
Does any one know about AVIDeFreezer, ive tried this but cant get it to re-create a repaired file.
please help -
you can try a tool called DivFix. http://divfix.maxeline.com i haven't tried it yet,but until virtual dub fixes its "scan bug" i'm afraid we have few choices.
Load the AVI file to VDub. Select Video-->Scan video stream for errors. Print out the error log. Go to first bad frame select Mark In. Move one frame down (">>"), select Mark Out. Press the delete key. Continue until all your bad frames are deleted. Save the file.
Hello.
Lags while playing AVI(XVID) (no frozen frames)
By Feone in forum Newbie / General discussionsReplies: 8Last Post: 11th Apr 2011, 11:47 -
Last few minutes of video frozen...
By JohnC1726 in forum RestorationReplies: 3Last Post: 14th Jan 2010, 09:56 -
Frozen frame when going from.mov to .flv?
By beanguy in forum EditingReplies: 1Last Post: 10th May 2009, 12:27 -
swf to avi - last few frames of animation get cut in the avi - any solution
By perfection in forum Newbie / General discussionsReplies: 0Last Post: 5th Sep 2007, 09:01 -
usb2 mouse keeps frozen up after no using it over night
By deejay.2001 in forum ComputerReplies: 2Last Post: 13th Aug 2007, 18:42
