  1. I have a collection of small to medium size avi files. I want to convert these to VCD format. I am presently using the TMPGEnc PLus 2.5 program and using it ok. But I cant seem to find a way of encoding the whole batch of avi's in one go....I can only seem to encode each avi one by one. In other words I'd like to throw them into one encoding batch and walk away.
    Can you advise what the correct procedure is.
    Thanks. 8)
  2. Tempeg has a join tool in it use that to join all files up to size of cd
  3. Tmpgenc also has a batch encode option. To use it you have to set up a project file for each encode. To do this, load your first .avi, adjust any settings or load templates etc then select file-> save project. Repeat for each avi file. Once you have done this select file->batch encode and ADD each of the projects and hit run. It will now encode each project one after the other. You can then use the mpeg tools option to join all the mpegs if that is what you want.
