  1. Im having the most problems.....
    I ripped my dvd and got some files.....but they end in .m2v and .ac3
    ...The problem im running in to is I can't find a program that will change them into .avi or mpeg...and .wav
    help please...I need detail instructions...
  2. Am I supposed to start with smartripper and have my two files (.m2v, .ac3)?
    If this is correct, why won't my program support ac3 files?
  3. ok...one more thing...I ripped with smartripper,
    opened dvd2avi...loaded the first .vod file...and all my options are not available.( like im using an older version) but I went directly to website and got....ver 1.77
    anotherwords.....I cant change my .ac3 file to an avi....
    what do I do?
  4. If you are wanting to turn it into a VCD file then i suggest that you use the software on my site (it's Freeware) untill you feel a little more confortable.
    http://www.eazyvcd.tk
    DVD to VCD made eazy
