I have seen some where on here how to do this, but i can't find it, help.
How can I look at the details of an mpeg, i woild like to know whether
NTSC or PAL
16.9 OR 4.3
and things like that
I will never learn
You can check by load mpeg file into TMPGenc and check resolution and frame rate. If frame rate is 25 fps mean your mpeg file is PAL, 23.976/29.97 goes for NTSC.
To check if it is wide screen(16:9) or full screen(4:3), is kind of hard. Most of the time mpeg files are in 4:3 full screen even though you see the movie in wide screen/letter box format. So you can check resolution if it is 352x240 (NTSC), 352x288(PAL),and 320x240 (normally use when capture and no standard), these three resolutions are in full screen(4:3). Other than these I don't know
This is not all yet. You have serch more and read more to know all about it. All I mentioned above I assumed that you were talking about VCD or mpeg1. If it is mpeg2/SVCD all about resolution will be a little bit different.
Add Codecs Column to Details in XP
By DarrellS in forum ComputerReplies: 27Last Post: 20th May 2014, 13:56 -
Title Details
By duzmor in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 18th Aug 2009, 19:43 -
HDD Speed details
By rizvii in forum ComputerReplies: 1Last Post: 7th May 2009, 01:36 -
JVC 'loading' repair details
By Jack Africa in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Apr 2009, 02:19 -
Is there a way to find your registration details?
By Nitro89 in forum ComputerReplies: 3Last Post: 19th May 2008, 11:20
