    Aug 2002
    What is the best oftware to rip a dvd and can you put them in order pls and where can i find a uide that has all of them
    ScootZilla
  2. Depends if you want SVCD or VCD.
    for VCD i recomend my software "Eazy VCD v1.01" http://www.eazyvcd.tk
    and for SVCD i recomend "DVD2SVCD" http://www.dvd2svcd.org/
    DVD to VCD made eazy
  3. Whats is best vcd or svcd? SVCD HUH? is it?
  4. If your DVD can play them, SVCD is excellent. Better picture quality and better sound. On the downside you dont fit as much onto each CD but that in part is why the quality is better.....
    DVD2SVCD - excellent and simple to use
    For those occasions when it does not work do it long hand-
    SmartRipper
    DVD2AVI
    TmpGENC ( VCD or SVCD)
    ChapterXtractor
    Vcd Easy
