I've been playing with DVD Workshop, and somehow I created a menu with res 720x576. The motion vids looks great. So I try to create another menu using DWS for another movie. Now all my menus are res 352x288 and the vids are very blocky. I even tried to use the clips used for the first 720x576 menu. Results in menu res 352x288. WTF.
I need a clue. I can't seem to find the setting in workshop 1.2.
TIA
OK. I figured it out.
Now. Anybody out there know how to add the motion menu to vcdeasy?? Something about converting it as the first .vob file in the svcd dir. I am playing with vcdeasy trying to figure that out.
TIA. -
Check out the "AUTHOR" section. I learned just by following one of the guides there.
Its very easy: just pick an MPEG clip, then go to that sequence and then choose what you want the number buttons on the remote to do. I don't think you can actually place text into the clip; that all has to be done beforehand. The possibilities are endless.
Endless. -
Ur right markums2k. I reread SLOOOWLY the guide until i understood what it was saying and it's done by manipulating the options in the interactive tab.
I now my problem is it will not accept my hi-res motion menu (720x576) if my vids are 480x576. Something about not PAL compatible. I dunno why they are 480x576 after converting the divx's with dvd2svcd.
I'll try to converting the menu mpeg to 480x576 via tmpgenc or womble.
thanx.
Replacing DVD menu made by ConvertXtoDVD
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 4th Oct 2010, 04:39 -
editing text in menu in an already made dvd
By gameroftheuk in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2008, 21:32 -
Trying to copy a dvd made using convertxdvd no menu shows up
By brdhsby5 in forum DVD RippingReplies: 18Last Post: 17th Apr 2008, 09:33 -
philips 3400/37 - unable to duplicate dvdr made
By freebird1963 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Sep 2007, 12:56
