I have a dvd with old black and white cartoons. I can rip the dvd but cannot make a good copy of the cartoons as the action is not smooth it is like yoy can see some of the lines jerking. this does this even when previewing the rip. The dvd does play fine. Can anyone help with this.
I used dvd decrypter and dvd to avi.
ok that worked thanks for the help
the sorce is possably Interlaced.
if you are going to AVI, use DVD2AVI to frame server it then encode in "Virtual Dub" and run a DeInterlace Filter on it.
If you are going to Mpeg, use DVD2AVI to frame serve it then encode with "TMPGEnc" and after loading the template, click settings then click on the advanced tab, and use the DeInterlace filter there.
Hope this helps =8-)DVD to VCD made eazy
http://www.eazyvcd.tk
New cartoon resolution
By CaZeek in forum Capturing and VCRReplies: 5Last Post: 18th Oct 2010, 11:22 -
Where can I download Legend of Prince Valiant 1991 cartoon serie season 1&2
By strijdparel in forum ComputerReplies: 1Last Post: 19th May 2010, 19:34 -
Video to Cartoon
By MarioB in forum EditingReplies: 1Last Post: 2nd Nov 2009, 09:30 -
Cartoon Animation
By dbanga in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 11:46
